effects of slippage
When You say MPG, miles per gallon? If so you might see a little. Last clutch I had slipping on me It started when crusing in 5th (nissan 300z) and I went to accelerate, the rpms would climb up alittle with out verry much acceleration. Then it just got worse from there untill it was slipping in ever gear. If your clutch is starting to slip you should start to notice it in the tach more so than MPG. Try putting it in 6th and flooring it see if rpm's start climbing faster than car is accelerating. Or you can try pulling the E brake and letting out the clutch if the car has a hard time stalling or doesn't stall you have some problems. Hope this helps good luck.
thanks. ive already noticed all that. Im asking because im getting about 11-12mpg's and cant quite figure out why. Changed o2's, retuned the idle and pt throttle.....checked almost everything mechanical that I could. If thats taking the 6-7mpg then id be happy to spend the $ for a new clutch, but not another spec
no new mods. just happened all of a sudden and no codes. i monitor it with EFIlive and everything seems normal as does the tune. So with that I figured it has to be something mechanical.
