Pacesetters + TSP catted Y + Dynomouth disappointed!!
Originally Posted by blkZ28spt
Rasp free??
Sorry, that's a negative.
To get rid of rasp you need to run cats and/or switch to a different cat-back. There are better mufflers than a dynomax bullet that you could stick in there (borla XR1, sweet thunder, etc), but even then you will still have some rasp.
But as stated, you are going to need some type of different muffler
the XR1 will get rid of just about all the rasp, my buddy has an XR1 hooked up to this mac's/ory and he has minimal rasp with his so I'm assuming that with cats, rasp won't be a problem
I put a moroso spiral flow bullet muffler in my ypipe before a cutout and that got rid of alot of rasp and interior noise when the cutout is open....its alot better sounding than it used to be
-Zach
-Zach
Originally Posted by jlashley2001ss
where u get this moroso spiral flow bullet at?
Edit: PM sent
im disappointed w/ my setup . i thought this would be totally rasp free setup???? WTF.
also do u guys get banging with ur y-pipe???? WHAT DO I DO??? chime in on this please!!!!!!!!!!!!!!!!!!
Poly motor mounts would more than likely fix it but that does take some time, I know of a couple of guys that actually took a stock valve spring and mounted it to the top side of the y pipe, with a large hose clamp, that was banging, between the y pipe and the floor pan and it took care of the problem.....talk about inovation
