Required Changes for Increased Fuel Pressure
I recently installed a Ractronix fuel pump and my fuel pressure jumped from around 52 PSI at idle to 68 PSI. During a few quick WOT blasts, the pressure never dropped below 60 PSI. I tried searching, but found little information regarding tuning for fuel pressure changes.
Could any of you lead me in the right direction (I'm using HPTuners)? I'm assuming I need to alter the IFR table, but I'm not sure what exactly I need to do to it.
Thanks,
Josh
Thanks,
Josh
Ashville NC **** yeah I grew up in Brevard.
Have no idea about decreasing pressure I dont think there is a way with any tuning software, might try lowering the voltage from the pump. Why is it a problem. Hopefully someone who knows more will jump in.
Is the problem because your return fuel line isn't big enough to allow enough flow back into the tank at idle? (causing the pressure increase at the injectors) if so, a new regulator won't help, you will need a larger size return fuel line.
