Revers Lockout.
Old 06-25-2005, 09:25 AM
goober35's Avatar
Default Revers Lockout.
I am doing an a4 to m6 swap. I have everything wired up exsept the revers lock out. Will the PCM be able to control the revers lockout noid. It is an A4 PCM but it has a pin 44. Or will it only work when i have the PCM flashed over to a M6 tune?
Old 06-25-2005, 10:15 AM
1madss's Avatar
Sorry, don't know that one for sure. I would suspect that you would have to have it reflashed to have the M6 functions (come on, you know you want that skip shift )
Have you checeked the conversion sticky above? I thought I saw something on that in there. If not you might try asking in the PCM section.
Good Luck with you conversion.
Old 06-25-2005, 01:09 PM
goober35's Avatar
I am not going to hook up the skip shift.
So to get into revers i am going to have to fight that noid. Damn that is just sux.
Old 06-25-2005, 01:28 PM
tippmann243's Avatar
im not doing the exact same swap as you, but i am running into a similar problem
i am swaping in a 350 t56 into a gmc sonoma
i was planning on hooking the reverse lockout to my brake light switch, or even just getting a shift **** with a button in it to control it or my last resort would be a switch on the dash
the only think i woory about with hooking it to the brake light swithc, is it getting over used and going bad
i duuno, hope this helps
Old 06-25-2005, 01:48 PM
slowpoke96z28's Avatar
is the solenoid part of the housing? if not make you can just unbolt it and fabricate a block-off plate.
Old 06-25-2005, 04:14 PM
true, but the purpose of reverse lockout it st prevent shifting into frever when trying to hit 5th
and i would rather have it installed and never need to use it than not install it, miss a shift and **** something royaly
Old 06-25-2005, 10:37 PM
if your trying to keep it functional, you'll have to reflash the pcm or hook up a switch to energize the solenoid when you need/want reverse.
Old 06-25-2005, 11:56 PM
CamdLs1's Avatar
Thats what I did, wired it up to my nx panel switch, I had an extra button, and its right there next to the shifter.
Old 06-26-2005, 02:23 AM
goober35's Avatar
Got any specs on it or pics.
Old 06-26-2005, 12:06 PM
goober35's Avatar
OK i am going to wire the Lock-out to the PCM. Does the PCM have a wire coming out of pin44 or do i have to go and get a pin. And if i do need to get a pin where can i get one or what would i use?
Old 06-26-2005, 12:24 PM
Wyckedcamaro's Avatar
Ok I am running into the SAME EXACT problem.
I JUST did the a4 to m6 and trying to throw it into reverse with the car off OR on is a royal BITCH.
I dont have the reverse lockout as a regular m6 has. But I also dont have the skip shift problem. My mechanic said I would just need to tune it out because he couldnt find the hookup to put the eliminator in. So I have the eliminator for sale but that is neither here nor there.
Anyways.. my shifter is alittle TOO notchy and a bitch to bang 3-4 for some reason. Like I have to come over a quater inch when coming down.
Reverse got hung up on me 2 days ago. IO couldnt get it to come out. I had to eventually pop the clutch while pulling hard on the shifter for it to "pop" out.
No problems since then. But the throwing it into reverse is a BIIIITCH!
Quick Reply: Revers Lockout.
