Nitrous Oxide - track results with nx dp kit!!
Juicedz
06-25-2005, 01:15 PM
First problem of the night came when I found out that my bottle heater wasn't working, but I tried to manage with out. I had two ten pound bottles that were full. First run, bottle pressure was at 1100 but dropped to 850-875 at the end, and I ran a 11.26 @123 w/ 1.75 60'. Second run I changed the bottle, lowered tire pressure to 10psi from 12psi, and opened the bottle to a 950 psi. Second run I ran 11.02 @123 with a 1.66 60', and bottle pressure dropped to just above 900. I am spraying a 200 shot, and the car was tuned at 1050psi. Last time I went to the track my bottles were warmer but, never more than a 1000psi and I trapped @126. Any ideas on how much hp I am losing going from 1050psi to 900psi? If I get my 60' down to a a 1.50, is there a possibility of going 10.50's @ 127-128-129?
Juicedz
06-26-2005, 12:02 PM
ttt......
V6 Bird
06-26-2005, 12:13 PM
The answer is no.
Juicedz
06-26-2005, 06:00 PM
you sound pretty confident with that answer, how fast is your car again?
Josh@PremierAutosports
06-26-2005, 07:55 PM
Did you trap 126 with the 6 speed or the th400? How was the weather compared to the 126 run? I would say you are down 1.5-2 from the bottle pressure but not the 4-6 mph you are looking for unless you you get a way better DA.
Elite_Hot_Rod
06-26-2005, 08:04 PM
Don't get defensive man, you asked a question and he gave you his opinion. BTW, his car is faster than yours, he runs low 10s.
Juicedz
06-26-2005, 10:32 PM
I wasn't getting defenseive, he just sounded confident because no explanation was given, just a simple no answer
Juicedz
06-26-2005, 10:34 PM
I trapped that with the th400, but again my bottle pressure was still around 900psi. The only thing I changed was, I went to the full 28x10 drag, from the hoosier qtp-27x10.5. The weather was actually alittle cooler, but I had probably a 12-15mph wind coming right at me. I gained 2.5mph in the 1/8th but lost 3mph in the 1/4
Elite_Hot_Rod
06-26-2005, 10:52 PM
If you can get your 60ft down to a low 1.5 you will probably run a 10.9 possibly a high 10.8. You'll get better times when the weather cools off, if the car stays consistant maybe a 10.7, not to bad.
V6 Bird
06-27-2005, 07:50 AM
I wasn't getting defenseive, he just sounded confident because no explanation was given, just a simple no answerI have a weak dick dry kit on my car that is pretty old...When i had a stock internal setup the car ran 10.7's @ 3400 lbs with me in it. Now the car has a cam and a little better exhaust and runs a tiny bit better. 150 more psi in the bottle will not pick up .5 seconds of elapsed time. I figured I didnt need to explain that to you. You asked a simple question and I gave you a simple answer. That is all.
Juicedz
06-27-2005, 08:26 AM
the thing is i tuned on the dyno at 1050psi, I do remember when my pressure was 900 or so I was only picking up around 100 horse because my a/f waslow 10's some times even high nines
NXRICKY
06-27-2005, 08:51 AM
The mph is lost cause of your tire height, and difference in tires mfg and style, 28x10 Drag what??? Slick or radial. You lost an inch in diameter quite a bit of change there. Also the weahter can have huge part in mph. The 60's ft, seem a little off. Are you hitting at the launch or waiting to turn the nitrous on. To get the car into the 10's that 60 foot has to come down.
Ricky
V6 Bird
06-27-2005, 09:28 AM
What cam, heads, etc. What plugs do you run, etc. You should be bottom 10's with 200 pills in a 34-3500 lb car with a good combo..Sounds to me that something is out of whack. WIth 200 pills the car should be making over 600rhwp...Is it even doing that? I see its a LT1 car....What ar ethe specs of a zz409?
Juicedz
06-27-2005, 01:30 PM
the specs are 226 duration both intake and exhaust, and a .555 lift., afr 190cc headfs with a 56cc chamber, tci 10"ultimate street fighter,-3800 stall I did put down 510 on the 150 shot through a moser 12 bolt and 4:10 gears
Juicedz
06-27-2005, 01:33 PM
Ricky
sorry there was a typo. I had hoosier qtp 27x10.5 when I trapped 126, I then switched to the hoosier full drag 28x10, that nitrous is coming on as soon as the t-brake is released, keep in mind that my 1.66 time was still with 11psi in the tires
V6 Bird
06-28-2005, 08:02 AM
LSA on the cam??? Whats the intake centerline? Im not a huge fan of the specs soo far...That may be why you are not getting as much as you could out of the combo...
NX_CaGEdApE00
06-28-2005, 04:25 PM
you were spinning with the 27" tall tire causing you to trap a higher mph.
with everything in check and a better 60ft i see 10.50's easy.
get it all worked out falconey
You would also want to take a look at the convertor a 10in is pretty big.That will hurt your 60ft.And the cam is not the best choise for nitrous you want a split duration.
Robert56
06-28-2005, 09:35 PM
Ricky
Ricky, or anyone else, do you know the formula for tire diameter change and affect on gear ratio. I have the same problem and forgot about the diameter thing. My new DR's are about 1/2 to 3/4 inch shorter (in hieght, don't know dia yet) than old tires and my trap speed average went down. So did my gear ratio right?
