Nitrous mishaps
Old 06-26-2005, 10:44 PM
joblo1978's Avatar
Default Nitrous mishaps
I'm trying to learn all I can about Nitrous.
Can everyone post their nitrous mishaps, the circumstances around it and the damage it caused?
Old 06-27-2005, 02:05 PM
joblo1978's Avatar
Nobody has damaged there engine by using nitrous in here? Either a faulty part of the kit, too big a shot, or any of the other things that can go wrong?
Old 06-27-2005, 07:05 PM
slow trap's Avatar
a friend with a m6 decided to spray out of the hole but let the clutch out first which bogged the motor then hit the switch=BOOM !one less ls1 motor! luckily no mishaps for me ,YET!with all the safety features,ESPECIALLY A WINDOW SWITCH,it would probably still be alive and kicking.
Old 06-27-2005, 11:08 PM
camaro98z28's Avatar
None here....
Old 06-27-2005, 11:18 PM
Robert56's Avatar
Had a n2o noid stick open.
Old 06-27-2005, 11:37 PM
Nitro Dave's Nitrous Outlet's Avatar
You will notice that almost 99.9 percent of Nitrous Mishaps are from user error.
Out of all the cars I have tuned on the dyno I have hurt two.Both were shop cars and we knew we were pushing the car to the limit.
Follow the guid lines set and use the saftey products on the market and you will have tons of fun.Most important buy a quality system.
Dave
Old 06-28-2005, 06:24 AM
tektrans's Avatar
I broke my driveshaft in two and cracked my trans on a nitrous attempt.
Engine is fine though
Old 06-28-2005, 11:29 AM
NXJeremy's Avatar
Had a fuel solenoid not open due to a swelled piston. Kind of a crazy thing, I was at the track with my T/A when it was bone stock w/ a 150hp wet NX system. Car went from 9.0's to 7.60's on the nitrous. Plugs looked good so we didn't think anything was wrong. On the last pass I decided to spray it at the launch, well it launched very hard (I was on slicks) and about the time I was going to hit 2nd gear it went boom. When we pulled the motor apart I found that I had 100's of pieces of #7 piston in the oil pan and that the wrist pin had welded itself to the rod which punched a fist sized hole in the cylinder wall. Still never found out what would have caused the fuel piston to swell shut. I don't know anyone personally that has ever had that problem though.
It gave me a good excuse for building the motor that I really wanted to begin with, haha.
Old 06-28-2005, 12:50 PM
Matt@HSW's Avatar
I've had a fuel piston swell shut before (TNT kit). We linked it back the the additives (nitromethane and ethanol and other oxignators) in the Sunoco 94 we were using at the time.
Old 06-28-2005, 01:07 PM
NXJeremy's Avatar
At the time that is what I was thinking. I was mixing 93 out of the pump with some VP Performance Unleaded (110 octane I think). But a friend of mine was running the same thing and still does today without any issues so I don't know what caused mine to swell, I chalked it up to just bad luck, it happens every now and then.
Old 06-28-2005, 07:37 PM
joblo1978's Avatar
This is some good experiences, let's keep 'em coming if we can. I'm not looking for anything really radical. Just a 100-150 shot on a cam with ALL the safety features. Maybe when the car is completely paid off I'll get more extreme.
Old 06-28-2005, 07:47 PM
GM Muscle's Avatar
I also had a piston seal swell up and not open from using Sunoco 94. Luckily I caught it and the motor was ok. I switched to a different piston seal and things have been great ever since.
Old 06-28-2005, 09:45 PM
Robert56's Avatar
You guys probably know allready, but for those reading along, there are noids made for alternative fuels, Nitromethane, alky and others.
Old 06-29-2005, 05:21 AM
GM Muscle's Avatar
That's excaly what I ended up with. I just got a piston with a seal for nitromethane applications. The seal is like hard black plastic, not like an eraser material. It's worked really well, doesn't leak, and my solenoid actually opens when I want it to.
Old 06-29-2005, 06:06 AM
badass 2002 z28's Avatar
I melted a plug on the dyno and had a cylider load up with fuel causing a nice fireball and a melted piston
Old 06-29-2005, 08:07 AM
Matt@HSW's Avatar
Correct, there is. The downside is when the fuel manufacture stops adding the additives then the new pistons swell. Can't win them all I guess. Most of these problems with fuel solenoid plungers swelling is limited to cretin regions of the country.
Old 06-30-2005, 07:08 AM
1ScrudeDude's Avatar
Preventable? Or a freak thing?
Old 06-30-2005, 07:27 AM
Nostang's Avatar
I had my #7 stock injector lock up on my NOS dry kit back in '97. Popped the #7 ring lands and took a chunk out of the piston.
Old 07-02-2005, 04:48 AM
Kind of hard to say...
The car went rich one one bottle pass then super rich on the 2nd (after leaning out the fuel)...I couldn't make any sense out of it so I should've stopped right there...the 3rd pass it blew
Was it preventable? only if i stopped after the 2nd pull. a freak thing?..it was for me cuz I never would've expected it to happen
