confusing oil pressure
Old 06-27-2005, 12:20 PM
2000slpss's Avatar
Default confusing oil pressure
ok my oil pressure at operasting temp idling is a tad over 40 psi. when i leave the line hard the pressure climbs slightly like it should but drops to just under 40 almost imedately. when i shift to second it momentarily climbs to a little above 60 flutters between 60 and 40 and then sits at 40 and when i shift to 3rd it goes to a little over 60 and stays there till i stop accelerating. what could be causing this? i thought mayeb coming of the line the pump was getting starved of oil but i checked the leve land it was only a half quart low. could my pump be going bad? thanks for any help
chris
Old 06-28-2005, 11:01 AM
2000slpss's Avatar
any ideas?
Old 06-28-2005, 11:03 AM
777's Avatar
I would replace the pump before you have to replace the engine. How many miles are on it. That just doesn't sound good.
Old 06-28-2005, 12:40 PM
blkZ28spt's Avatar
I'd stop going WOT. I assume that's what follows leaving the line hard....and 40 psi is pushing it at 6k rpm. If you follow the 7psi per 1k rpm you just make it, but if you want 10 psi per 1k rpm you don't even have that.
Old 06-28-2005, 02:09 PM
2000slpss's Avatar
its a 72,000 miles its wierd how its doing that because all the way to 6k in 3rd its at 60 psi but in 1st and 2nd it drops to 40
