2 stage wiring on same wot and window switch.
Is it possible to hook up 2 stages to the same window switch and wot switch and just have 2 different buttons to control them?
Im going to be running a 2nd stage thats dry and the first will be wet. I really dont want to buy the stuff 2 times if possible. I didnt know if there is some way to do this or not..
thanks for the help.
yeah i want the same rpm for both.. I probably wont use them both at the same time much anyway.. I really just want to be able to use a 100 shot or a 50 shot depending on who im racing.. then have a 150 if it was needed.
So basically would I just split the wires from the wot switch and the window switch to two different relays?
