Question about NOS kit
Old 06-30-2005, 10:14 AM
Kens98TransAm's Avatar
Default Question about NOS kit
I just had my 75 dry shot completed....im just wondering how long do you hold it for when you run the car.....Is a couple of seconds ok??? thanks
Old 06-30-2005, 11:32 AM
fstphx's Avatar
the majority of the people on here run wide open throttle switch, that way when the pedal is down you are spraying, then a window switch so you dont risk anything.
Old 06-30-2005, 12:06 PM
Matt@HSW's Avatar
fst_phx is correct. You should look into getting a WOT (or TPS) switch along with a window switch. A fuel pressure saftey switch is a good idea too.
Old 06-30-2005, 12:11 PM
Yup i have the WOT switch.....im just wondering how long should i spray for???
Old 06-30-2005, 01:02 PM
fstphx's Avatar
Till the Bottles empty man
But other than that im not sure of the question-
Old 06-30-2005, 01:40 PM
Matt@HSW's Avatar
Do you mean what RPM band should you spray in? I don't quite understand the question.
Matt
Old 06-30-2005, 02:06 PM
Nitro Dave's Nitrous Outlet's Avatar
From reading your post it seems that you are doing highway runs.
It really comes down to the solenoid.NX says not to spray longer than 15 to 20 seconds with there 093 nitrous solenoid.Of course keep in mind that you also do not want to over spin the motor.
Now if you are talking about a quarter mile run its ok to spray it all the way down the track.unless you run slower than 20s.
If you are talking about RPM band.Keep it above 3,000 rpm and shut it off where you shift at but before rev limiter.
Dave
Old 06-30-2005, 11:06 PM
Yes im talking along the lines of Nitro Dave.....This will be my first time using it...it is for 1/4 mile racing....i have the WOT switch....the car is an a4.....im just wondering and would like to know when should i spray...(example rpm range, what gear, etc...) THANK YOU for any info and advice
