TSP 224 or F13, or other? So many cams, so many choices which one?
There are so many cams out on this board my head is spinning. I think I've narrowed down to two choices, but only b/c they are the most poplular, the TSP224 or the Futral F13.
This car is a weekend/daily type driver. Most my time is spent btw 1500-4000rpm, and a few rips up to 5500-6300 rpm. Goal is to have an increase in torque through the whole rpm band at minimum, and the obvious increase in hp. Target numbers are 410rwhp+ and torque. Definately want that choppy cam sound, have a show car, want a show/go sound too.
(Mods: Janzer ported TB, smooth bellows, lid/green filter, FLP longtubes w/ high flow cats, B&B Tri-flo catback, predator tuning, stock rear all on a 02 WS6.) Will use stock head only.
From what I gather, the F13 seems to be the most miraculous cam in providing both low end torque and good hp. Haven't seen too much on the 224 cam. I also believe the F13 is more streetable/drivable than the 224. Is this true?
Are there other cams to look into that would provide this benefit I overlooked? Right now TSP has an awesome sale going on, but if this cam is not going to provide what I need/want, then I will wait till something else goes on sale.
Thanks for any help and suggestions to a cam newbie
I don't know about the TSP 224 but I do know about the F13. I have it and I love it. I didn't hit the 400 mark but got close. Probably would have but I cheaped out and didn't get the ported throttle body and the UD pulley. If you get the F13 you will need to get a tune to take full advantage of it. I was running a tune for my TR224 when I put the F13 in and it did pretty good but I picked up about 24 more HP when I got it tuned for the F13.
The 224 won't get you 410. The F-13 prolly won't get you that either. You aren't going to get much lope from the F-13. Depending on what you biggest prioraties are I'd go with the F-14. It will lose a little low-end from the f-13, but it will get you closer to that 410rwhp. It will also lope a lot more.
