new slave
new slave
I got my new slave today and was wondering a couple things.
First what is the large bearing like thing that came with it? I haven't seen anything on here about it.
second I am going to use my stock master and was wondering do I still have to bleed it? It looks like a quick disconnect of some kind for the slave to master line.
Ok I just checked the one that came with the spec clutch and its the same thing just the bearing is on it, instead of the way it came with the slave.
Thanks
Now does anyone know about the question on bleeding the master?
Thanks
The slave should be ready to go and should not require bleeding but many others have indicated that when replacing the slave they had to do a bleed. Put it together and check you pedal and cross your fingers that it's ok. I did a bleed on mine to replace the fluid and I used the gravity method w/o any problems.
