Which mods provide most HP gain?
Hey, out of this list of mods, what should I replace or get to increase HP on an lt1 engine? How much HP would I get?
Subframe Connectors
Strut Tower Brace
Springs
Shocks
Sway Bar
Panhard Rod
Torque Arm
Tunnel Brace
Lower Control Arms
Front Upper A-Arm
Front Lower A-Arm
Throttle Body
Mass Air Flow
Roller Rockers
Cold Air Intake
Valve Covers
Heads
Air Inlet Elbow
Ignition coil
Ignition Box
Ignition Wires
Electric Water Pump
UnderDrive Pulleys
Timing Chain
Performance Clutch
Front C5 Brake Upgrade
Rear C5 Brake Upgrade
Driveshaft
12bolt Rear End
3.73 Gears
LT4 Knock Module
Short Throw Shifter
255gph Fuel Pump
Subframe Connectors
Strut Tower Brace
Springs
Shocks
Sway Bar
Panhard Rod
Torque Arm
Tunnel Brace
Lower Control Arms
Front Upper A-Arm
Front Lower A-Arm
Throttle Body
Mass Air Flow
Roller Rockers
Cold Air Intake
Valve Covers
Heads
Air Inlet Elbow
Ignition coil
Ignition Box
Ignition Wires
Electric Water Pump
UnderDrive Pulleys
Timing Chain
Performance Clutch
Driveshaft
12bolt Rear End
3.73 Gears
LT4 Knock Module
Short Throw Shifter
255gph Fuel Pump
only thing on that list of suspension and drivetrain mods that would give any kinda increase in hp is....heads, CIA, tbody, and EWP. for your first mods, i would go with the Cold air induction, then some rear end gears, then work on everything else. if your on the budget i would get some ported stock heads and a cam, along with all the suspension and drivetrain to support it.
Subframe Connectors
Strut Tower Brace
Springs
Shocks
Sway Bar
Panhard Rod
Torque Arm
Tunnel Brace
Lower Control Arms
Front Upper A-Arm
Front Lower A-Arm----- these are all suspention, aka no HP gain, but ET gains
Throttle Body- 8 HP
Mass Air Flow-3 HP
Roller Rockers- 15 HP
Cold Air Intake- 10HP
Valve Covers- 0
Heads- depending on which ones 20-35
Air Inlet Elbow- 1 if that
Ignition coil
Ignition Box
Ignition Wires
Electric Water Pump
UnderDrive Pulleys
Timing Chain- no HP gain but ET gains
Performance Clutch- nothing to BHP but 5 or so RWHP
Driveshaft
12bolt Rear End- no HP gain, but ET gains
3.73 Gears- no HP gain, but nice ET gains
LT4 Knock Module
Short Throw Shifter
i mostly rounded up- they are certaintly arguable, just my 2 cents
(ones left black and either only ET gains, or no performance gains, but all are nice products to put on/ essential to make car run better)
Strut Tower Brace
Springs
Shocks
Sway Bar
Panhard Rod
Torque Arm
Tunnel Brace
Lower Control Arms
Front Upper A-Arm
Throttle Body- 8 HP
Mass Air Flow-3 HP
Valve Covers- 0
Ignition coil
Ignition Box
Ignition Wires
Electric Water Pump
UnderDrive Pulleys
Driveshaft
LT4 Knock Module
Short Throw Shifter
Originally Posted by greatskiiiier
Subframe Connectors
Strut Tower Brace
Springs
Shocks
Sway Bar
Panhard Rod
Torque Arm
Tunnel Brace
Lower Control Arms
Front Upper A-Arm
Throttle Body- 8 HP
Mass Air Flow-3 HP
Valve Covers- 0
Ignition coil
Ignition Box
Ignition Wires
Electric Water Pump
UnderDrive Pulleys
Driveshaft
LT4 Knock Module
Short Throw Shifter
Strut Tower Brace
Springs
Shocks
Sway Bar
Panhard Rod
Torque Arm
Tunnel Brace
Lower Control Arms
Front Upper A-Arm
Throttle Body- 8 HP
Mass Air Flow-3 HP
Valve Covers- 0
Ignition coil
Ignition Box
Ignition Wires
Electric Water Pump
UnderDrive Pulleys
Driveshaft
LT4 Knock Module
Short Throw Shifter
Get a lt4 knock module also. You don't want the computer to pull timing when it senses false knock, due to performance upgrades.
And for gods sake get rid of that opti spark A.S.A.P.
