I cant wait to get it! No more frieing PCM's for me.
I must admit as a prior owner of Edit, it is nice not having to cross your fingers everytime you hit the program button with Flashscan. I found this made things so much easier when doing the trans shifts after a diff gear change, there is NO WAY I would ever reprogram the PCM out on the road with Edit, with Flashscan, you just pull over and know that failing a laptop battery failure you'll be off again in under a minute.
