12-bolt OR 9"? Which is best?
Old 07-01-2005, 08:55 AM
BIG_MIKE2005's Avatar
Exclamation 12-bolt OR 9"? Which is best?
Ok i have been reading alot of posts & i see just as many people sayin they like the 12-bolt just as much as a 9". So the real question is, which one is the strongest & provides the best performance & reliability for a daily driver/ weekend warrior. Also which one is more cost effictive.
Old 07-01-2005, 09:05 AM
fattdaddyLS1's Avatar
Great ? I'm interested in this aswell!
Old 07-01-2005, 10:31 AM
777's Avatar
9" hands down. It is quiter, stronger, cheaper. Faults not as effecient (robs a little more power), weighs more (unless you get a billingley fabbed 9"), can't keep ABS unless you have a 4-channel rear (tcs/abs)
Old 07-01-2005, 10:45 AM
ok, time for another great question related to this.
If the 9" rear is supposed to be better(as in strength, quality, quietness, & price)
what attributes make it better?
P.S - I dont mind long posts so anyone who can fully explain this feel free to fill me in completely. When i go to purchase my rear, i want to be as educated about it as humanly possible & completely confident i purchased a rear that will probably never again have to be replaced.
Old 07-01-2005, 11:19 AM
Derek98z's Avatar
parts are cheaper for a 9". Not really sure if it is any quieter as noise is usually associated with gears. The quality really depends on what brand of rear you buy as 9" and 12 bolt is generic. But as a rule, they are both good pieces regardless who builds them. 9'" uses a 9" gear and a 12 bolt uses an 8.75" gear (I think). thicker the gear relates to stronger gear.
Old 07-01-2005, 11:33 AM
ok, then lets get specific. Which brand is the best also. Moser or Strange or whatever else there is out there. I was really wanting a moser, so is the moser 9" better than the moser 12-bolt & why? And i do have TCS & ABS.
Old 07-01-2005, 11:46 AM
what is a good price for a used 9" or 12 bolt (used as in less than 1000 miles)
Old 07-01-2005, 11:55 AM
Derek98z's Avatar
I believe if you want to keep ABS, you must get a 12 bolt. That is unless someone is now making a 9" with ABS.
I paid $1,400 + my stock 10 bolt for a soft locker 9". I see most 9" go used between $1,400 and $1,700. But I have seen them with all the options go used for $2,000 +
Not sure on 12 bolt pricing as I have never shopped for one.
Old 07-01-2005, 01:42 PM
Bryan @ Speed Inc.'s Avatar
i have a moser 12 bolt w/ a 4.10 gear, eaton posi, 33 spline axles and the abs option. cost 2,200 new. the only thing i didn't get was the alum. diff cover. it's NOT noisy. a little more noisy than stock but definately nothing that pops out at you. you'll get a little more power to the ground and it will be a little lighter with a 12 bolt. i have not had a problem w/ mine yet. i love it. however, if you want the strongest rear end possible regardless of any other factors, the 9" is it. moser and strange are both great quality companies. i think strange is a little better quality... it's also a little more expensive.
Old 07-01-2005, 03:07 PM
zwentbyyou's Avatar
Advantages for a 9 inch are that they don't usually break and you can change out the gears in no time. You wanna run an all motor setup throw some 430's in or what have you and then if you wanna go the following week to the track and spray the **** out of the car you can swap out to a lesser gear.
It does rob you of power and is heavier but you can make up for that with the bottle
Old 07-01-2005, 03:30 PM
TCrow2002WS6's Avatar
I know a 12 bolt is obviously stronger than stock 10 bolt. And you can break the stock one by just dead hooking when launching. What would it take to brake a 12 bolt?
Old 07-01-2005, 05:51 PM
00sscam's Avatar
I have a car that makes 407 at the wheels not impressive when compard to the rest of the guys on the board. I can tell you i had my Strange 12 bolt rebuilt 2x and it still screamed like a banchee. That was all with in half a year. I pulled the dame thing out switched to a 9" and have never been happier 12 bolt may be fine for the auto x guys but it will not handle 3600lb cars launching at 5k they were not designed for that. 11-1200hp no problem it is the weight of these cars that eats up the 12 bolts.
good luck
Old 07-01-2005, 06:02 PM
LoPeY's Avatar
Yes you can. A heavy car, a hard launch, and good traction are a recipe for a damaged or destroyed 12 bolt.
Old 07-05-2005, 01:43 AM
Jimmy P's Avatar
A six speed is much more likely to break a 12 bolt than an auto.
Old 07-06-2005, 05:53 AM
10 Second Club + 14 Second Truck Club
antz01ta's Avatar
my car
broke it once, rebuilt it with the parts that should have came in it from moser and all is good now.
Old 07-06-2005, 07:31 AM
1ScrudeDude's Avatar
From my understanding, it is the posi that gives.
They break in BOTH the 12 bolts and 9" units, right? To the guys who "broke their 12 bolt..." can you be more specific please?
Old 07-06-2005, 08:02 AM
I would like to know also. Im planning on about 450-500 RWHP by ther time im done with all my mods. And it will be a daily driver/street racer/weekend warrior. So which one (9" or 12-bolt) is the best choice for reliability & performance?
Old 07-06-2005, 02:23 PM
antz01ta's Avatar
ok clutch packs that came in the rear from moser were carbon fiber and had 400lb springs which are stock replacement pieces = pos. replaced with 24 disc steel clutch pack and 800lb springs. have been good since replaced running @ 600rwhp. if you are buying a rear make sure you specify you want the 24 disc steel clutch packs and 800lb springs or you will be replacing them if you like to "use the posi" if you know what i mean.
Old 07-06-2005, 05:04 PM
pontiac's Avatar
I have a moser 9" WITH ABS AND WITH TCS
Old 07-06-2005, 08:36 PM
ibepressin's Avatar
If I can ask pontiac.. where did you get it? and how much? any complaints?
