Tip for first time clutch changers (OEM)
Old 07-02-2005, 03:59 PM
redmist's Avatar
Default Tip for first time clutch changers (OEM)
I found out the hard way. On the OEM clucth you have to depress the pressure plate and turn the adjusting ring counterclockwise ALL the way before installing. If you don't the clutch won't engage and you will blow out your slave cylinder.
Clutch works perfect now.
Old 07-02-2005, 06:12 PM
GETSOMZ28's Avatar
I didnt do that on mine, and it works just fine. Are you talking OEM F-body clutch or ZO6 clutch?? I used the ZO6 in my Camaro.
Old 07-03-2005, 06:09 AM
redmist's Avatar
I don't remember whether it was a vette or f-body clutch. You might have lucked out as there is a range of adjustment rather than an "on-off" setting. I order to get maximum engagement it has to be fully adjusted. I suspect this is the reason some people have such short lived clutches. Partial adjustment will result in engagement but not full clamping force.
Old 07-03-2005, 09:44 AM
GETSOMZ28's Avatar
I am also running an adjustable master, so that may be part of it too. I will have to look at that on the next clutch I do (hopefully not mine).
