Holes in runners....
Hey guys. I just installed my PRC's and was wondering about the holes in the intake runners that go into the rocker bolts. I hear thats how they are but do yuo patch them or anything??
thanks.
thanks.
Originally Posted by SPANKY LS1
No. Put some tread sealant (blue locktite) on the rocker arm bolts, and put 'em in. Every ported LS head I've seen has those holes.
Shawn
Shawn
Nah use the red, it holds much better
Restricted User
Wayne, let Andrew dip your bolt in his red stuff and you wont get off! You can use locktite or RTV/Silicone, but I would discourage you from sealing the hole (opposed to just sealing the threads), as it can trap water/oil etc and work against the torque value and possibly cause issues later on.
Restricted User
Thread over locktite. And only on the intake is it necessary, since those are the bosses that are exposed after porting. Some ppl use locktite on all the bolts to prevent them walking out, I never had an issue with that on my car or others I wrenched.
