1" rear bar installed.
Tech Addict
what a difference, the stock bar looked puny by comparison.
really tightened up the back half.
now i need to install the bar Mark gave me.
While I was under there I noticed the pre-load posts for the diff rear main caps were seeping. anybody else have this problem? thread sealer? a precision application of teflon tape? I want to remedy this situation when I change the fluid next weekend.
Tech Addict
Originally Posted by WAHUSKER
Teflon tape is a must on those!!!
Is the front sway bar bigger than your stocker?
What's the best grease to keep these from squeaking. A full synthetic of some kind?
Tech Addict
So, another question.
Would this bar improve all around traction?
It seems since I installed the bar the tires don't spin as much, during my 1-2 shift on the street my tires only spin roughly half as long as they used to go up in smoke. Less wheel spin at launching too.
The bigger rear sway bar will keep the car more level in the back during launches... which could result in your straight ahead traction being better, since the weight transfer should be pretty evenly distributed between the rear tires now.
Of course, I still smoke 'em up easy in 1st gear... just the rear end doesn't start drifting to the left so much when I do it.
