Max HP from a stock 99 Vette with 30lb Injectors
Old 07-05-2005, 08:33 PM
Mr Powell's Avatar
Default Max HP from a stock 99 Vette with 30lb Injectors
When will we run out of injectors with 30lb injectors. This is using a dry nitrous kit. ~550 or so rwhp sound about right????
Old 07-05-2005, 08:54 PM
JMBLOWNWS6's Avatar
I think that RWHP is more the limits of the SVO 42#'s.
Old 07-05-2005, 08:56 PM
Mr Powell's Avatar
Ive seen 550rwhp out of a all motor car with 30s. Is the limits with a dry kit much higher????
Old 07-06-2005, 09:37 AM
V6 Bird's Avatar
If you tap into the Coolant temp sensor on the passenger head and make it go instant rich with some relays you can spray quite abit on STOCk injectors just by jetting the kit to an AF ratio of your liking...There was a guy with a setup similar to this on here...Might want to run a search on it. Quite interesting honestly and it makes sense too.
Mike
Old 07-06-2005, 10:39 AM
Mr Powell's Avatar
Mike you do not remeber his username on here by any chance??
