Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Any one in the Detroit area, i need help
Old 07-06-2005, 05:24 PM
ThirdGenLS1's Avatar
Default Any one in the Detroit area, i need help
Alright just got my ls1 into my 3rd gen camaro done and i keep throwing this stupid clutch input switch malfunction code. I called speartech and he told me to just delet it. I really dont feel like spending like 150 dollars to send the comp off again to get one code deleted. So i was wondering if there was anyone around in the detroit area that has some kind of tunning device that can delet this code for me.
Thanks a lot
Justin
P.S. - i'm located at 9 mile and jefferson in saint clair shores.
Old 07-06-2005, 06:49 PM
ta12sec's Avatar
you should be able to get a resistor of the same omhs as the switch if you can figure out where to put it youll be all set as long as you dont have cruise control. is it hooked up to the clutch switch ?
Old 07-07-2005, 09:06 AM
n2ojunkie's Avatar
IF its just the switch adjust it. its right by the clutch pedel and it looks like a break sw and works off the arm of the clutch. its a whole lot cheaper.
Old 07-08-2005, 12:28 PM
the switch is just fine, the computer just doesnt read it becuase its from a third gen camaro. I called speartech and he told me he just delets that code cause it always goes off in his conversion. So i was just looking if anyone in the area had a tuner that could delete it for me.
Thanks
Justin
Old 07-11-2005, 08:30 AM
Scooter70's Avatar
Justin,
What year is your PCM? I have HPTuners for 2000 F-bodies. PM me if yours is a 2000 and I'll fix it up for you.
Old 07-11-2005, 12:18 PM
damn, thanks tho, its a 01 pcm.
Thanks anyways
Justin
Old 07-11-2005, 12:26 PM
Thanks anyways
Justin
Quick Reply: Any one in the Detroit area, i need help
