fuel pump install
fuel pump install
I have a 255lph Walbro fuel pump. I went to install it the other day, and realized if I wanted to drop my fuel tank I would have to cut my back off of my exhaust. I have heard people do it my cutting above the tank. Can someone PLEASE walk me through the install or give me a site that has detailed instructions to the install. Is it possible to do the install without dropping the tank at all? Is if ok to do? Any cons?
Thanks,
Justin
Thanks,
Justin
i raised my car realy hi in the air and took the bars off for the rear end and dropped the exhaust down and then the tank make sure the tank is empty and you can do it yourself i did its easy
I've decided on doing the trap door method. I need some 5/16" high pressure fuel injection rubber hose, fuel injection hose clamps, and a small stainless steel clamp to hold the pump inside the rubber boot. Where can I get these items?
