Removing heads with pacesetters info plz??
Hello yall i have pacesetter LTs the car is on rhino ramps now. I loosen the header bolts and the header droped down. It looks like i can loosen and reinstall the new heads on the passenger side but i am not sure if its possible on the driver side without lifting the car higher to drop down the headers more. Is it possible to get to the bolts and loosen and reinstall new heads without removing the LTs? Any tips and info would be greatly appreciated. Thank you very much for your time to read this thread.
i just pulled my heads with my pacesetters still connected to the y pipe - i pulled the passenger side first then after that i went to the driver's side and gave the headers a tug away from the head - with the head off the passenger side, the whole assembly pulls over far enough to get at the bolts on the driver's side - you will have to maneuver the headers around while removing the bolts from their holes but it wasn't terribly hard
