Burning Anti-freeze whats the cause
Old 07-07-2005, 02:46 PM
91sbcamaro's Avatar
Default Burning Anti-freeze whats the cause
i got a 2000 Camaro LS1 and it will drive and run but after about 10-20mins of it runnign it will start putting white smoke out(anit-freeze) what could be the causes and ways to check the exact problem?
Thank you!
Old 07-07-2005, 02:51 PM
BirdMan 1585's Avatar
You Mean White Smoke Through The Exhaust Or Where
Old 07-07-2005, 02:53 PM
ss rally red's Avatar
Thank you!
White smoke out of the tail pipes? commen causes blown headgasket or worse. There are kits available ot check for CO in the colling system,there shouldn't be any. Or get a shop with a 5 gas analyser to stick the prob over the radiator filler neck to check for CO also.
Old 07-07-2005, 02:57 PM
91sbcamaro's Avatar
yea its coming out of the exhaust sorry i didint mention that...so check if theres CO in the anit-freeze? how exactly do i check that? or is there another way to check for head gasket?
Old 07-07-2005, 03:55 PM
blue01ta's Avatar
Pull the head. Check to see if you have antifreeze in the oil or vice versa.
Old 07-07-2005, 04:00 PM
91sbcamaro's Avatar
ok so what im coming up with is the only EASY way to check the gasket is to do a CO test?
Old 07-07-2005, 04:18 PM
~JOSHUA's Avatar
Drain the oil. If it's milky looking then your head gasket is hurt and is letting oil and water mix. Hopefully that would be the only problem. But accept the fact that there is a problem and at the very least it means changing head gaskets. Plan on turning some wrenches.
Old 07-07-2005, 04:48 PM
blue01ta's Avatar
Hopefully you have another car you are driving now. If you are getting coolant in the oil it won't lubricate near as good as it should and can be very bad on the engine.
Old 07-07-2005, 05:13 PM
91sbcamaro's Avatar
yea i dont drive it at all so ill look into checkin the oil and going about replacing the gasket? anyone have any pointer n know-how before i dive into the head?
Old 07-07-2005, 05:28 PM
I thought the 2 ways I mentioned were fairly simple The only problem with just checking the oil for coolant contamination is coolant can be getting burned off in a cylinder(thus the white smoke) but it may not be getting in the oil. But if coolant is getting into a cylinder then combustion WILL be also present in the coolant,thats why its always best to check for carbon monoxide in the cooling system
Old 07-07-2005, 05:51 PM
91sbcamaro's Avatar
where do u find the CO testing kit that was talked about?
Old 07-07-2005, 07:07 PM
I know the tool trucks have them..Snap on/Mac etc. but I think you could find them a AZ/Pep Boys... thew screw on the radiator like a pressure tester and have a pump at the top, you pump the tester and if turns a different color usually blue in most cases it hac CO in it,not a good sign....
