pegged out my N2O pressure gauge
Old 07-07-2005, 07:18 PM
69_YENKO's Avatar
Default pegged out my N2O pressure gauge
I sprayed a 150 TNT shot with an estimated 1,750PSI bottle pressure
Just kidding about the spraying part .
I picked up my 15# bottle this morning after filling it for the first time. It had been sitting in the floor board while I was at work & after comming out at 4:30 i discovered what you see in the above picture. Actualy the needle was covering the "N" of NOS just touching the other screw. that picture was taken after filling a bucket with cold water and dunking the bottle in it to try and drop the PSI quickly. it just makes me wonder at what PSI will the bust disk release pressure. this bottle had to of been pushing between 1,700-1,800 PSI
Old 07-07-2005, 07:23 PM
150shotWS6's Avatar
wow
Old 07-07-2005, 11:21 PM
69_YENKO's Avatar
Originally Posted by 150shotWS6
wow
I was freaked out when i first saw it . Im not sure what to do with the 100+ deg weather were having here in west Texas. I cant put the bottle in the car at all or bottle pressure is going to jump way up above that 900psi that my TNT kit is rated at.
Old 07-07-2005, 11:25 PM
WickEdSix98's Avatar
Damn stuart, give some of the extra pressure to me! When are you gonna spray it?
Old 07-07-2005, 11:36 PM
markp03's Avatar
my friend tests highpressure cylinders like that one and much bigger...you don;t have to worry, the bottles rated for 1600 psi will hold over 3000 psi
it's all about safety undamged cylinders will hold WAYYY over what they are rated at.
Old 07-07-2005, 11:46 PM
69_YENKO's Avatar
I knew the bottle would hold like 3,000+psi, I was more worried about the burst disk rupturing letting $60 (yeah i get fucked paying $4 a #) of N2O out into the cab of my car before i ever got to spray any of it. when will the burst disk blow out?
Old 07-07-2005, 11:51 PM
69_YENKO's Avatar
When you start spraying, I,ll let you have all the extra pressure you want .
I put the 100 shot jets in earler today, I might test her out this weekend.
Old 07-08-2005, 12:35 AM
V-10 Killer's Avatar
NX blowoff valves are 3000psi, I think.
http://www.nitrousoutlet.com/outlet/...3&section_id=5
Consider yourself lucky. I blew the backs out of two liquid filled NOS bottle gauges within 2 weeks, and mine only hit around 1250psi.
Old 07-08-2005, 01:32 AM
setxws6's Avatar
Get dark window tint, put your t-top visior shades on, and get a bottle blanket.
