vibration through clutch
Old 07-09-2005, 01:03 PM
bmfcamaro's Avatar
Default vibration through clutch
i just started having a really bad vibration when i push in the clutch. you can feel it through the pedal and the stick. i am stumped. i would imagine its my flywheel or clutch. i have a spec stage 3 thats about a 1 and a half to two years old. anyone want to take a stab at this.
Old 07-09-2005, 01:11 PM
LS1Tech Sponsor
Slowhawk's Avatar
Might be a shot pilot bearing.
Old 07-09-2005, 02:48 PM
bmfcamaro's Avatar
i did replace that. wouldnt that throw out a high pitch though. i dont have any extra noise just crazy vibration. i checked my mount and its still bolted tight. poly mounts.
Old 07-12-2005, 10:25 AM
bmfcamaro's Avatar
t t t
Old 07-12-2005, 10:50 AM
Restricted User
NOSjohn's Avatar
Is it at a specific RPM or throughout the range of the motor? You might want to check the bolts on the PP and flywheel. Did you tighten them to spec., in a star pattern, WITH lock-tite?
Old 07-14-2005, 11:57 AM
bmfcamaro's Avatar
yeah 2 years ago though. it seems to be more present above 2000 rpm when i try to shift. i really dont have time to take the tranny out right now that is why i am trying to get a heads up.
Old 07-19-2005, 09:03 PM
bmfcamaro's Avatar
anyone
Old 07-20-2005, 06:47 AM
Dustin Butts's Avatar
Did this just start all of a sudden? Have you replaced anything at all very recently? It does kind of sound like a loose pp. Need to get it checked out before something lets loose in there and causes a major problem.
Old 07-20-2005, 10:59 AM
amazza76's Avatar
I have gone thru 4 spec stage 3 clutches and each time had a vibration similar to what you describe...turns out I was breaking the springs in the sprung hub. Input shaft had way to much play. You probably have fried your pilot bearing and the input shaft is moving around to much.
Old 07-21-2005, 12:52 AM
bmfcamaro's Avatar
it just started after my last set of mods heads and intake. i am thinking its the pp or flywheel. i will take it apart next week.
Old 07-21-2005, 08:27 AM
Like amazza76 said input shaft looseness can cause problems. I just had my trans gone through and my input shaft had a LOT of play in it. My pilot bearing was chewed all to crapp, practically vaporized. Nothing but a bunch of metal powder in there. I had to pull it all out with a magnet. I had shifting problems and strange vibrations etc.
Now everything is golden. Smooth as a baby's booty.
Also, check the small (approx.) 1/4" dowel pins that are located at the 3:00 and 9:00 positions on the trans mounting face. Make sure these are still in there. Sometimes they get lost, removed or mashed into the bellhousing. They are supposed to be tapped in to and remain in the trans. The help properly located and center the trans.
Old 08-22-2005, 03:08 PM
bmfcamaro's Avatar
everything looks good except the spring in the clutch hub. one is flopping around in there all the rest are tight. i guess this is my problem. any suggestions on clutches. I WAS THINKING SPEC STAGE 4.
