Speed Density Tuning Ready to Take Off????
Old 07-09-2005, 09:45 PM
SPIV's Avatar
Default Speed Density Tuning Ready to Take Off????
Now that Dynojet have released an eddy current dyno will "Mafless" or speed density tuning take off in the USA as it has done in Autralia due to us having had Eddy Current dyno's for many years???
Old 07-09-2005, 10:34 PM
Fetumpsh's Avatar
It's not a new concept to the US, the early TPI Small block ran SD for a few years.
Old 07-09-2005, 11:02 PM
SPIV's Avatar
True, it is not new but.....the lack of readily available eddy current dynos has meant that you cannot easily tune each rpm/TP/MAP point since you need to hold the rpm and load constant to do this. All the top tuners in Australia have been using this methodology for over two years now with awesome drivability results with big cams.
Old 07-10-2005, 01:21 AM
405HP_Z06's Avatar
You can also use a Dyno Dynamics dyno, waaaaayyyyy better than the Dynojet!!!!!
Once you tune on one you won't use anything else.
