what pill to use for my window switch i got a 3800 stall
Old 07-09-2005, 09:55 PM
violator3434's Avatar
Default what pill to use for my window switch i got a 3800 stall
just curious what i should change my pills to on my window switch, im putting in a f14 cam, 3800 stall, and i have all the bolt-on in my car plus racetronix fuel pump. not to sure what rpm i should spray and stop spraying at. probly be doing 100 to 150 shot.
thanks
Old 07-10-2005, 01:33 AM
calongo_SS's Avatar
Depends on several things. You will need to see if you can hook out of the hole w/ a 3000 pill (if you're planning on spraying out of the hole). Do you want to spray through the shifts? What are your shift points?
Old 07-10-2005, 02:21 PM
charlie c5's Avatar
Find out from your tuner what your shift points are and set your window switch to pick you nitrous kit off at 150 rpms before your shift. It's not a real good ideal to spray through your shift points, transmissions don't really like it...
