sounds like rocks bouncing around in the rear?
Old 07-10-2005, 01:21 AM
TAwananbe's Avatar
Default sounds like rocks bouncing around in the rear?
When I put the car in first or reverse I sometimes hear noises from my moser 12 bolt..........in almost sounds like I have rocks bouncing around in the rear end????
BTW, my ujoint is a little loose? Maybe it just got looser?
Old 07-10-2005, 12:29 PM
TAwananbe's Avatar
TTT please? Anybody?
Just seems to be when going slow or backing up outa the driveway.......??
Old 07-11-2005, 10:28 PM
tattooZ's Avatar
Default rear end noise.
Generally, when it is a u-joint problem. It will start with a creaking sound more than anything and mainly in reverse. If you say that the u-joint is loose. I would definitely take care of that problem first.
Quick Reply: sounds like rocks bouncing around in the rear?
