Help! - Monsoon LOC'd
I have no idea what the hell is going on but, something weird has happened. Went out Sat. Night to hear a band. Got to the place about 9:30pm (looked at clock on Monsoon when I parked and it was 9:35). Came back to the car to leave about 2:30 - 2:45am. Get in, start 'er up, look at the clock and I see "LOC" in the display. Never seen this before but, now the stereo won't turn on. I can load and eject discs but, no tunes. What happened?! My first thought was that maybe somone tried to break into the car but, no signs of that, nothing's missing. No signs of any physical abuse to the exterior either. Has this happened to anybody else? How do I un "LOC" my Monsoon and get my music back?? Please Help!!
Oh man... look in your owner's manual for exact instructions, but it has to do with the delco theftloc.
there's a code that you'll have to put it using the head unit... if you're the original owner, then you or the dealer put it in... if not, then the original owner probably activated it and set the code. From my experiences, you WILL need that code... maybe there's something that GM can do for you if you don't have it.
Good luck... if you don't have your manual, let me know, I'll type the instructions out for you later.... as for now, I'm off to bed before work tomorrow.
Does anyone read the FAQ ?
https://ls1tech.com/forums/wiring-stereo-electronics/303776-frequently-asked-questions.html
https://ls1tech.com/forums/showthread.php?t=303776
Copy & Paste Moderator
https://ls1tech.com/forums/showthrea...light=theftloc
These are two of many threads. At some point the code you puch in on the phone changed and the second thread above mentions that and lists the new code.
It worked for me recently. I will look into it.
It seems that the phone system/message may have change a while back.
…here's something else. I don't know if this has anything to do with it but, last month when I installed my new Infinity Kappa speakers I also installed the GM9-AUX cable for iPod hookup. Everything's been working great since the install. Saturday I was in the garage detailing the interior and I was listening to the iPod through the Monsoon with the ignition in ACC mode. First time I had done that. Sounded great, worked fine. And, the battery is a Delco from the dealer which was installed less than 2 years ago. I've had no problems at all with the battery. Anyway, once I got the code and unlocked the Theftlock, stereo and CD worked fine but, no iPod. So, I did the first thing I always do when troubleshooting problems with electronics. Power down and check connections. Pulled the HU and unplugged the GM9-AUX cable and re-seated all the plugs. Everything works fine now. So… what do you guys think? Gremlins?!
I am not surprised about the GM9-AUX. Mine didnt work for the first minute that it was installed and just suddenly started working. I had this happen with two different headunits. I think the issue is with the headunit seeing and learning what it is. There is just some delay in the headunit.
