How long did your RAM last
Old 07-10-2005, 07:57 AM
BDD
BDD's Avatar
Default How long did your RAM last
I am interested in the new RAM PG, but I do a search and I find all of these problems. I want to know how many miles you got out of your RAM clutch; mainly the PG system. Also if you had any problems.
Old 07-10-2005, 03:11 PM
Y2K SS's Avatar
What problems?? Please list thanks. I've had mine for about 4k now with about 20 hard runs on it. Still going strong.
Old 07-10-2005, 08:49 PM
bboyferal's Avatar
Welcome to the world of seemingly ALL aftermarket clutches lately.
Old 07-10-2005, 08:55 PM
LS1Tech Sponsor
Slowhawk's Avatar
402PP
3160 plate
Billet flywheel =
980miles before the PP welded to the flywheel in my TA.Easy fix but got rid of it because the Pedal Pressure just plain sucked (too hard)
Old 07-11-2005, 08:08 AM
CATCH ME's Avatar
400 miles and it slipped so bad it had 300-500 heat fractures in the PP. upgraded to the HD and its been fine and strong for 200 miles so far.
Old 07-11-2005, 08:18 AM
Strahley's Avatar
The only problem I've had in my setup has been a weak factory & carquest throwout bearing. My flywheel and clutch (both HD RAM products) have been running great for about 10k miles or so. Clutch grabs hard, doesn't slip, doesn't miss a beat at all
Old 07-12-2005, 02:51 AM
LS_WANG's Avatar
10 miles, clutch was gone because I tried to cut corners by not installing a new adjustable master, and didnt upgrade the slave. Good thing I ordered from summit, back the clutch for a year.
Old 07-12-2005, 02:23 PM
plumbr's Avatar
About 800 miles with 520rwhp on juice. Approx 15 track passes on slicks.
Had high rpm pedal pressure problem from the begining, pedal would get soft after a hard run through a couple gears. Finaly wouldn't disengage at all, replaced all hydrolics with an adjustable master proplem persisted.
Pulled clutch found disk wore down to nearly nothing. Replaced clutch with out doing any additional work to the hydrolics and it works perfect.
I believe that there was a p/p problem with my ram causing pedal feel and disengagement problems. Now in need of a tranny rebuild as well.
Old 07-12-2005, 02:48 PM
brokez's Avatar
Has mine about six months and it had good pedal pressure. But one day going down the freeway the damper spring came off the clutch and took out my flywheel and pressure plate as well as 3rd gear . So if I could do it all over again I would not choose ram.
Old 07-12-2005, 02:49 PM
WS6GoFast's Avatar
7 days and about 400 miles no big problems except one day it was chattering really bad at about 1500 rpm which is where i have been using it. it works like normal again now. buy and adj master cyl when u get it tho, after they break in it loosened back up
Old 07-12-2005, 09:39 PM
ninobrn99's Avatar
well i just ordered my pg hd...lets hope i have luck with it!
Old 07-12-2005, 09:50 PM
94redz28's Avatar
Me too
Old 10-09-2005, 05:52 PM
Mr 35th's Avatar
NOt long I had two of them and they lasted less than 1000 miles each. POS Spec 5 all the way.
Old 10-09-2005, 09:55 PM
glennster's Avatar
Ram HD with 3-4 thousand miles and about 30 track runs with no problems.I'm not dumping it either,I use a controlled slip and even hotlapping it has no ill effects.Used a new stock master/slave with no shim.Great clutch.
Old 10-10-2005, 05:43 PM
98nosz28's Avatar
I have 5000miles on mine. A few track runs, but lots of highway runs,0-120mph. It still holds great. I get 3rd gear rubber shifting at 7000rpm so I think it holding great still. Its the Ram HD. I had a Centerforce DF B4 and blew it apart first time to the track.
