Misfire SES....
i know what you mean but if you dont have the scanner and arent monitoring it i wouldnt turn the light off. I would just set the p0300 low misfire table to 32767 and that should cure 99% of the light issues unless you had a real problem in the upper RPM that needs to be checked ASAP (ie broken valve spring)
Restricted User
Wayne, if you send me the file, or swing by the house after your work I can set you up. As mentioned above, and in my email and talks, with your lil cam, it SHOULD NOT be KR, or misfiring, but if it is you'll want to know, which is why I mod the low rpm and part mid rpm slowly trimming the cells that need less sensitivity. Also, do like had emailed to troubleshoot the ****. FuckahBrah!
