Transient fuel tuning
Has anyone delved into modifying the transient fueling params? With all the modifications to heads and intakes there has to be some change with the way fuel "puddles" and is consequently atomized or evaporated.
I just like studying this stuff I doubt I would actually try and retune it, unless I found enough info on it to feel confident about it.
From what I understand it concerns how much fuel is left on the intake walls. I just wonder how it is controlled since fuelo obviously evaporates a a set rate and temp. How does it effect injectors?
Restricted User
Originally Posted by CAT3
I know some ppl have, whether they want to chime in? I would like to one day tweak those tables to maximize not only my tune, but for pure knowledge. I can see it being beneficial for smoothing out the pcm's functioning from idle, to PT, to WOT and return and generally just making the whole thing more efficient.
heres some good reading its indepth and not easy though
http://www.delphi.com/pdf/techpapers/1999-01-0553.PDF
the tansient fueling is mainly concerned with emmissions during cold starts, I assume they used stock materials for testing as higher grade metals should heat and cool quicker. Like I have ferrea valves and would think they heat up alot quicker and cool quicker than stock valves.
Wonder the implications as calculations concern time
also valve events should have an impact also
