A question about HPT Scanner
Yes I do know that.My bad I wasnt clear enough on my question.But what position should the slider be at for the actual run(Like I was full throttle logging)For that speed would I want the slider in the default position ,in the middle?When I was watching my log at the slowest slider position,I was thinking I hope my car isnt that slow(LOL)
Thanks
Thanks
LS1TECH Sponsor
Yea, we don't have an actual real time playback speed. This is the first request we've had for that.
Your car will typically log at 10 frames per second.
VCM Suite 2.0 has the playback speed adjuster on the front page so its much easier to get to.
I was Just Curious Magnus,my logs are hard to read even in the slowest mode ,between having to hit play then quickly over to pause just dont get it.I am having a hard time seeing my shift when I hit second gear and at what speed.Will 2.0 be better for this?I hope so....
LS1TECH Sponsor
Do you use the chart display? I highly recomend using the chart display, it is the most powerful display you will find in ANY product.
Also, contrary to what others may want you to believe, the gauge display (or dash display) is the weakest display you can use.
Just bring up the area that you are concerned in the chart about and mouse over the frames and you will see the #'s change frame by frame.
