Stays in closed loop at WOT
Old 07-11-2005, 08:19 PM
BLK02WS6's Avatar
Default Stays in closed loop at WOT
Got a car that won't go to open loop at WOT. It is in open loop when cold, then goes to closed loop when it should. Stays in closed loop after that.
I have checked everything I can find to check. Any ideas??
Old 07-11-2005, 08:22 PM
HumpinSS's Avatar
what FTC's are you seeing at WOT?
Old 07-11-2005, 08:31 PM
BLK02WS6's Avatar
I'll have to check the logs again, but I believe it was #22.
Old 07-11-2005, 08:35 PM
HumpinSS's Avatar
22 is open loop what makes you think it isnt transitioning from closed loop to open loop. this is Dirk bret
Old 07-11-2005, 08:43 PM
BLK02WS6's Avatar
I just checked the log and it is in 22. For one thing, FlashScan indicates that it is in closed loop at WOT - every other car I log shows correctly (reffering to the indicators on the dashboard) - and more importantly, it won't take fuel when you change the PE table - it won't richen up no matter what.
Old 07-11-2005, 08:54 PM
HumpinSS's Avatar
did you log commanded AFR by chance? GM.AFR_1
Old 07-11-2005, 09:01 PM
BLK02WS6's Avatar
I don't think so - I'll check. Is that a good one to log all of the time?
Edit - Nope, didn't get that one.
Old 07-11-2005, 09:07 PM
HumpinSS's Avatar
It will help closed loop will allways be 14.7 and when the car transitions to open loop you will see the Commanded AFR change ususally 14.7/PE multiplier will give you what the commanded AFR is supposed to be.... Can you send me the log
Old 07-11-2005, 09:10 PM
BLK02WS6's Avatar
Sure, can you PM me your e-mail address.
