Gear Howl When Decelerating
My whole rear end seems to make a clunk/whine/howl noise ONLY while decelerating.
-Both the car and factory rear end have 74K on them.
-I just bought this car not too long ago and according to the seller, he was using RP 75W-90 in the Diff (I'm assuming he installed the RP somewhere after the 500M break-in period...so it's probably almost 4yrs old)
-I recently checked the Diff Fluid and it was both full and clean looking. However I noticed signs of an old seal leak possibly (Hasn't leaked since I bought it 4K M ago)
-Car has only scene the drag strip 3 times (in late 2001).
Any idea's on what would cause this? I have read that it could be a loosened pinion-bearing preload...
sure does sound like a loose pinion nut. your going to have to take out the drive shaft, and check the pinion for play (side to side) and if you have a inch pound torque wrench (dial type) pre-load should be about 20-25 inch pounds. But if the crush sleeve is over crushed it's not going to work. If you have never worked on a rear end you might want to take it to a shop. It does get kind of technical some times.....
coast, deaccelerating, decelerate, decelerating, deceleration, end, firebird, gear, gears, howl, howls, noise, previously, quiet, rear
