Diff Year Bin Files
Old 07-12-2005, 10:51 AM
LETZ RUN's Avatar
Default Diff Year Bin Files
I have the same exact combo as a buddy of mine, with the exception of larger exhaust (i have 3" he has 2.5") and his car is an 02 Camaro and mine is a 99 TA. Can I burn the 02 .bin to my 99? We have the same cam, both ported tb, both pulley, both mti lid, both intake, etc etc. Mine has spray his does not.. but I can tune it for that if I can get his tune for the baseline.
Old 07-12-2005, 10:57 AM
Bill Bowling's Avatar
Talking
You do not want to use his tune. The two years are different. What tuning software are you using? In EFILive you could read his tune and compare and then copy and paste.
I have seen cars that are almost the same but the tunes are different.
Sound like you need a tune.
Good Luck.
Bill
Old 07-12-2005, 01:57 PM
LETZ RUN's Avatar
hptuners is what i have. can i just copy his values to mine. im just trying to get a baseline so i can start the car.. the current tune on the car would not be able to run i dont think (it was w/ blower 44lb injectors, yadda yadda)
Old 07-12-2005, 04:25 PM
Talking
What I would do is get a stock tune your same year and then change that one with his tables. That way you know if you miss anything they at least will be at stock. Check the bins at the top of this tuning thread.
http://www.horist.com/hptuner/search.asp?page=search
Bill
