Where is the fuel filter?
Old 07-12-2005, 04:31 PM
OdessitPashka's Avatar
Default Where is the fuel filter?
My o2 sensors are showing that I'm running lean and I think changing the fuel filter might help.
I searched but couldn't find any info on this. Where is it located? How hard will it be to get to it?
thanks
OP
Old 07-12-2005, 05:08 PM
7 Second Club
ty_ty13's Avatar
back by the driver side back tire... under the car
Old 07-12-2005, 05:13 PM
thanks a bunch man. I need to get a repair manual.
Old 07-12-2005, 05:15 PM
99blancoSS's Avatar
What he said and no its not hard to get at. You need the gm fuel line pliers or be practiced at the art of releasing those clamps. Push the two tabs in at the same time and pull. The correct pliers make it real easy but I'm sure some people must have some tricks.
Old 07-12-2005, 05:17 PM
thanks for letting me know about the pliers
Old 07-13-2005, 11:21 AM
99blancoSS's Avatar
they are $35 from snap-on
Old 07-13-2005, 03:08 PM
Maybe I'll just get inthere and get it off the way it is.
Old 07-13-2005, 03:28 PM
robertbartsch's Avatar
I doubt that an old fuel filter is causing your engine to run too lean but have a good time changing the filter without a wrench.
Old 07-13-2005, 03:36 PM
What do you think caused me to run lean?
Old 07-13-2005, 04:29 PM
Moderator
davered00ss's Avatar
installuniversity.com has a how to on changing the filter.
Old 07-13-2005, 04:32 PM
thanks man
Old 07-13-2005, 04:59 PM
Beats me??? Perhaps bad O2 sensors, LT headers, or other mods. How do you know that you are running lean; does your exhaust smell bad? Did you run a diagnostic, did you throw some codes, are you able to drive without any gas in the tank (my wife does this) or what?
Caution: lean engines tend to burn pistons, valves and other important parts... that help your engine go round and round..
Old 07-13-2005, 05:02 PM
2000WhiteTA's Avatar
You can use any type of pliers to remove the fuel filter. I use basic pliers and mine comes right off. I do not think that will help your running lean problem though.
Old 07-13-2005, 10:01 PM
I have another thread about this where I described the problem.
Got a SES the other day, I drive a bit and it goes away, then might come back, and go away again.
All my mods are in my sig.
I know that I'm running lean because that's what the scan tool told me. Went to adv auto and they printed it out for me saying that both sensors reading lean.
I know the problem that can be causes by lean conditions, but as I said, I don't think it can be something serious because it goes away.
Old 07-14-2005, 09:08 PM
calys968's Avatar
Are you sure you have a stock MAF?
Old 07-14-2005, 09:12 PM
Pretty sure. Previous owner was very honest about everything and told me every little thing he did to the car.
Old 07-23-2005, 08:46 PM
RED98WS6's Avatar
It's not that hard to do with your bare hands. I just did mine today.
Old 08-19-2005, 02:04 AM
ricethis98's Avatar
get HP tuners and tune your car.................... dont let a $6 and hr autozone kid tell u what your running
Old 08-19-2005, 08:47 AM
SiL3NtXWS6's Avatar
A bucket to catch the fuel was the only thing i needed other than my hands.
Old 08-19-2005, 09:23 AM
redbandit98's Avatar
yes its super easy to do..i always just pinch it with my hand and pull it off.
