ls1 with steel driveshaft?
Old 07-12-2005, 04:39 PM
sk346's Avatar
Default ls1 with steel driveshaft?
upon installation of my shift kit i noticed that my driveshaft had what appeared to be rust on it. yeah, my driveshaft has rust on it. i thought all ls1 f-bodies came factory with ALUMINUM driveshafts? mine is a 2000 a4 camaro - factory 273 car. wtf?
Old 07-12-2005, 04:46 PM
MontereyLS1's Avatar
nope.......2.73 cars came with steel driveshafts
3.23 A4 cars and M6 cars came with aluminum
Old 07-12-2005, 05:06 PM
2001NBMZ28's Avatar
My car came w/2.73's and the steel driveshaft.
Old 07-12-2005, 05:21 PM
GM Muscle's Avatar
Yep, only 2.73 cars got the steel shaft. Thing seems to be pretty strong though.
Old 07-13-2005, 06:29 PM
glennhl's Avatar
GM was not consistent. I have an 01 6 speed (3.42 gears) with a steel driveshaft.
Old 07-14-2005, 06:35 AM
GM Muscle's Avatar
That's pretty crazy. Your car must have been built on a Friday by the 3rd shift.
Old 07-14-2005, 08:47 AM
rufretic's Avatar
I wish I had a steel drive shaft, I would think it would be a good bit stronger.
Old 07-14-2005, 05:22 PM
ULTIMATEORANGESS's Avatar
did you buy your car new?
i broke one aluminum DS.
Old 07-20-2005, 12:54 AM
glennhl's Avatar
No, I'm the third owner. But the car was completely stock, not one mod. I first figured that one of the previous owners might have swapped with a friend before they traded the car in, however, I found out from this site that several people have 6 speed cars with steel driveshafts.
Old 07-20-2005, 11:12 AM
99PontTA's Avatar
the steel DS also has a nice vibration damper....makes for a smooth ride at high speeds...also has more polar inertia making second gear tire chirps easy
Old 07-20-2005, 02:17 PM
AnthonyR's Avatar
2000 TA auto 2.73 with aluminum DS here. I guess it depended on what they had available when the cars were built
Old 07-20-2005, 02:51 PM
jpscamaro's Avatar
don't you hate your 2.73s?
i have a 2.73 z28 and a steel driveshaft and every single 3.23 a4 walks on me. even with all my mods
Old 07-20-2005, 02:54 PM
EDS01SS's Avatar
My 2001 SS auto also came with a steel driveshaft and 3.23s
Old 07-20-2005, 04:08 PM
AnthonyR's Avatar
I guess I should have said had 2.73's. I don't anymore
Old 07-20-2005, 07:12 PM
GM Muscle's Avatar
Get the right converter in that car and things will change big time. I kinda like mine. Nothing like running mid 10s at the track all day and then knocking down 30mpg on the way home.
Old 07-20-2005, 08:15 PM
99HUGGRSS's Avatar
did you ever blow up your 10 bolt? is it a stock 10 bolt? what kind of TC are you using?
Old 07-20-2005, 08:27 PM
GM Muscle's Avatar
Nope, it hasn't spit any parts yet. I did add a gridle, stud kit, moser axles, and some heavy shock proof oil. Probrably spent $400 on it.
My torque converter is a Midwest 3500 stall with a 2.5 str. It could really use a 2.7-2.8 str though.
Old 07-20-2005, 11:15 PM
jpscamaro's Avatar
when you put a stall converter in your car doesn't your car just rev like its in neutral all the way up to your stall speed? ie 3800 stall conv. = goes nowhere until 3800+rpm..... how could you drive on the freeway, overdrive with 2.73s is like 2000 rpm at 80-85
Old 07-21-2005, 06:34 AM
GM Muscle's Avatar
No the car will actually roll at idle on flat ground. When coming out of stop signs and stuff I probrably only have to spin about 2,000-2,500 rpm to get moving at a normal pace. That's another thing STR helps with. A car with a higher str converter will feel "tighter", but if your running street tires that higher str will burn them off at WOT. On the highway at like 70 mph in 4th with the converter locked the car is literally at idle, I think it spins like 1,000-1,200 rpm. But to accelerate with traffic you just have to roll into it and as the rmps go up alittle the car will accelerate smoothly with the converter locked. Or if you roll into it alot the converter will unlock and your rmps will really go up.
Old 07-21-2005, 04:09 PM
LoPeY's Avatar
Those crazy Canadians must've made a big trip to the Beer Store while they were on break.
Quick Reply: ls1 with steel driveshaft?
