valve cover swap help
i changed to the center bolt valve covers and the ones i bought did not have the little fitting in the back for the pvc setup. i tried the dealer and then tried alot of vendors. i alread have the rubber gromet i just need that little fitting. does anyone have one or no anyone that has one?
Not sure about your year. But, on center bolt covers on the rear of the drivers side it has an elbow that is connected to a hose that routes to the passenger side valve covers where it merges with two outlets from the cover then it goes to a PCV valve shortly before the intake return.
The newer LS6 PCV system plugged the drivers side whole in the rear and just had one from the passenger side valve cover and a new exit point from the valley cover.
Sorry, I don't have a part number for that elbow.
