Nitrous Oxide - need help
2001z
07-12-2005, 07:56 PM
can someone take a pic or tell me how the hell the wot switch and braket mount in the throttle body.
code4
07-12-2005, 11:27 PM
OK, here's how I did it. But I don't know if your bracket/switch is the same. I took the 2 bolts out that hold the throttle cable bracket to the intake off. I found longer bolts & put spacers in to bolt the WOT bracket onto this bracket. You have to get just the right amount of spacing so that your throttle hits it just right. I did not have to bend the WOT bracket at all. Here is a pic with the throttle at Wide Open it works perfect. I think most others do it different by bending the WOT bracket somehow.
http://img.photobucket.com/albums/v448/code4/000_1225.jpg
2001z
07-14-2005, 07:54 PM
thanks man that worked great i used 3 1/4 in washers behind it and it is straight
code4
07-14-2005, 10:27 PM
I'm glad it worked.
JustAnIlluzion
07-15-2005, 02:56 AM
u can also mount it underneath the gas pedal
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
