lightest internals for a FI motor
Old 07-13-2005, 11:50 AM
7 Second Club
ty_ty13's Avatar
Default lightest internals for a FI motor
what are the lightest (yet strong enough) internals available for the iron 408... looking at rods, pistons, and crank.
Thanks,
Tyler
Old 07-13-2005, 12:30 PM
777's Avatar
Titanium, but you are looking at a lot of money and you most likely won't need it.
Old 07-13-2005, 12:53 PM
7 Second Club
ty_ty13's Avatar
no part numbers or shelf products?
Old 07-13-2005, 01:48 PM
777's Avatar
I'm pretty sure it's mostly custom. You could contact KATECH and ask. AFAIK the c5-r is the only lsx type engine using titanium internals except the new ls-7, which I believe uses titanium rods and valves. Be prepared to spend BIG, BIG, BIG money. Here's their website
Old 07-13-2005, 03:19 PM
Got Me SOM's Avatar
light internals in a heavy iron block, anybody see the irony in that
Old 07-13-2005, 03:22 PM
777's Avatar
Not really. You get light internals to rev higher, not to save overall weight. However, it is a little funny now that you mention it
Old 07-13-2005, 04:00 PM
BUYAMERICAN's Avatar
No offense, but buy the basic high quility steel stuff that you can get across the counter.
There are lot of good vendor engines builders here.
You simply can't afford the best. I will not even buy the best for a non commercially sponsered street car. The best materials are used in F1, IRL, Champ...
EG's. Titaninium rods, springs, valves. Carbon fiber block, carbon-carbon pistons, electrical operated 18,000-28,000 valve train, etc. Special coatings for everything. Try 90k for motor (maxmium and only a lease, you have to give back and cannot open it (IRL)), F1 is much more $$$$$. Try $100-400M a year to run a competative factory team.
Yes, the iron block is ironic joke. No offense, but your foundation is not even there.
Old 07-13-2005, 09:14 PM
CTSmechanic's Avatar
Carillio's... Callies crank good set of JE or CP slugs you wont find a ultra light weight piston that can take lots of boost if this was a NA motor then things would be different.Its gunna be funny when people start breaking the LS7 TI rods, Ti rods act like a serious jack hammer inside a motor... but thats just what I've seen a few times..
Old 07-13-2005, 09:15 PM
