Which Differential Cover??
Old 07-13-2005, 01:28 PM
CAMJAG's Avatar
Default Which Differential Cover??
Im about to do my first gear oil change in the rear and I want to buy a new cover... What are you guys using, or what would you recomend is a good one to buy? I was lookin at the one on the SLP web site but I need opnions. Thanks alot
Old 07-13-2005, 03:08 PM
SteveC's Avatar
Location: Poway, Ca. where GOD and the sun always shines
I use the "TA" girdle with stud kit.
SteveC
Old 07-13-2005, 04:04 PM
2001NBMZ28's Avatar
Same here.
Old 07-13-2005, 11:20 PM
Tech Addict
Rokko's Avatar
yup, same here. keeps the differential main caps from walking and spreading under power. it'll help your 10 bolt live longer. use a good synthetic oil too. don't forget the limited slip additive from gm.
Old 07-14-2005, 11:34 AM
CAMJAG's Avatar
Did the TA cover bolt right on with no modification?
Old 07-14-2005, 12:30 PM
2001NBMZ28's Avatar
Yeah, you can take a look at the install at http://www.installuniversity.com/ins...sity/index.htm
Old 07-14-2005, 01:24 PM
Jake19_2's Avatar
Im using the TA cover as well, 10 bolt is still holding up (fingers crossed).
Old 07-14-2005, 03:26 PM
SteveC's Avatar
Thumbs up
Yes it will bolt up without any modification, however when you order it, ask for the 2 longer bolts that hold the brake line brakets. Make sure you order the "stud kit" for the bearing caps.
I ordered mine from TyBurne.
SteveC
Old 07-15-2005, 01:25 PM
CAMJAG's Avatar
Sounds good thanks guys
