AFR 225 on stock bottom LS1?
I know that AFR recommends a large CID engine for the 225's... Just wondering how they would work on a stock LS1. Also, like to know how big of a cam I could run with the AFR 225's with a stock bottom LS1.
Yes, you can go with the 225's but the product you need (the 62 cc version) is still not available yet. Sorry bout that guys....we are doing the best we can. Hopefully soon.....
Tony M.
The 225 is at 72 cc combustion chamber. That would make you less than stock compression. Not good unless you have FI. AFR does not recommend milling the 225 to 62cc as is to get better compression - flow will be way off. So, AFR is creating a 225 head that ships at 62cc to get you a better compression for a stock LS1 and has the right flow.
Tony, fix whatever I got wrong.
We milled the 225s and then do additional port/polish work in house. Right now we hold the stock bottom end 346ci dyno record (Car is undergoing the knife right now with a new transmission before we can make more E/T passes) through a 9" with 35 spline axles. LSX 90mm Intake, NW 90mm TB, TTP Equalizer V 3.1 Camshaft, TTP S3 AFR 225s milled to 10.9:1 C/R.
Note: Red graph was another shop's H/C package we removed.
Originally Posted by Y2K SS
Why do you feel you need or want the 225's?? Are you planning on doing some heavy mods in the future.
Late Summer to early fall on the release of the 62 cc 225's. I think we will be seeing a handful of legit stock displacement 500 RWHP cars when this head finally touches down....
You guys will be the first to know...
Tony M.
Tony M.
Tony M.
Tony M.
Will there be a price difference from the current 225's and will the cam recommendations change? And if so, what would the cam spec recommendation be?
Tony M.
hey wat power will a stock ls1 make with the afr 205 cc?and wats a good cam?ive seen the slp has 2 packages with the afr 225 cc heads.ones for 500hp and the other for 600 hp only diffrence ive seen was the cam
