HELP!!!! Damn exhaust rattle won't go away!!!!
I purchased a Flowmaster american thunder after cat exhaust a month ago and have had a rattle. I searched through forums and found out about the heat shield rattle a lot of ppl experience. So I put some screws through it into the floorboard in the back at the front where the tube turns to go up over the axle. This was the only flimsy spot I found. Now its actually happening MORE!!!!!! I'm really pissed off cause my car sounds like *** when it rattles and am considering ripping the damn heat sheild off. Anybody that can tell me where else the rattle could be coming from I would greatly appreciate it!!!!!!
Mine still does this but with my borla ima have a shop check it out I think the dude charged me 10 last time but he misssed it and he wanted me to pay him again?!?!?! So I need to bring it by again just stop at the shop where you bought them and tell them to fix it it should be free or cheap man!!
have u tried to adjust or move the muffler around alittle bit, my flowmaster did that at the beginning but for some reason i guess it fell into place and it stoped. it only did it for me when i first started the car up, but once it heated up it stopped.
hmmm, you should do what i am gonna do and get rid of the muffler and weld a pipe where the muffler goes. my friend who has a LT1 has done this with stock headers and Y-pipe and sounds awsome, i figure no muffler there will be no rattle since the flowmaster mufflers are huge ***** F@#!ers.
Lol, yea, it is a big muffler!
i dont think a o2 sensor will make that bad of a rattle, you can clearly tell that it is coming from the muffler. but yeah i am gonna have my friend ditch my muffler and do the no muffler thing should sound mean as hell especially with a offroad Y-pipe. i dont plan on getting headers either since they seem like such a pain for little gain.
Originally Posted by hourang
my rear exhaust rattle comes from the ypipe to ipipe connection, i need to get mine welded but if i bang my hand there it makes the sound, stupid band clamp isnt working :/
Originally Posted by iosigma
DId you cut any pipes at all on install? If so did you clean out any metal shavings in the pipe and so forth? Just a suggestion
Originally Posted by Orange Terror
I don't think I have a problem there, it comes from the back, that would come from under me. But if this doesn't work I'll be looking there.
Friend of mine has the American Thunder Flowmaster on his '00 WS6. Sounded good for a month or two, now you can hear the exhaust rattling. Sounds like marbles in a can. The exhaust clears everything around it. It's just a piece of **** and sounds like the rattle is an internal thing. Hopefully that's not it, cause I'm sure you spent over 300 for that system.
i had a few rattles in my exhaust when i put it all on. I had a sheet of high temp rubber lying around so i wedged that in between the parts that were rubbing, ie. where the I pipe and the y come togather and a few heat sheilds. try slipping something like that under the band clamp, or junk it and get a good stainless u-bolt clamp.
Joe
Joe
Joe
Joe
