Key fob problems?
Key fob problems?
When trying to pop the rear hatch with the key fob I have to hit the button about twenty times before it pops. Is the key fob jacked up or is something else going on?
This seems to be a common problem. Mine works so far, but I can't use it at long distances at all. My friend has to press the hatch button twice, pull up (like ewilborn above) and then press it again.
I did the double spring fix. That's not a problem anymore. If you haven't done this, you need to. I have a new battery in the remote, I just have to hit the button about 15-20 times before the hatch pops. Any ideas?
