works one way, won't the other?
Old 07-17-2005, 02:58 PM
squall01's Avatar
Default works one way, won't the other?
today i was driving in the rain (an awesome time to drive these cars!!) i go around a corner and go to drift and the only wheel spinning is the RR. this was turning to the right. then i go around a left corner and try, and it works fine. so i'm wonder what the problem could be. when i try to slide it turning right, it starts to spin both, then the LR quits spinning and the RR takes off. Just looking for some help.
thanks,
bill
Old 07-17-2005, 03:43 PM
BillS's Avatar
That is normal, the unintended side effect of the the lighter duty torsen that GM had designed is that in a tight righthand turn the unit can "unlock". That is why the autox/roadracers switch to the Torsen T2R as it never unlocks. You can lose a lot of time on a tight autox if you unlock a stocker.
Old 07-17-2005, 05:52 PM
squall01's Avatar
it's just weird that i've never noticed it before. so it's possible to tail out one way, but not the other? hmm. anyway, do you have any links for a good place to buy a new diff?
