scaling IFR table
Old 07-18-2005, 06:30 PM
02sierraz71_5.3's Avatar
Default scaling IFR table
Recently installed larger injectors and I saw the stock ifr table was at constant value across the range, so I increased it by a margin ((larger inj/stock inj)*stock values) and left it. Then when I plugged in values into a spreadsheet the values where scaled upwards slightly.
What is the purpose of scaling the ifr table in a slight curve upward?
Old 07-18-2005, 07:08 PM
Texas Terminator's Avatar
with a stock regulator, it increases pressure with an decrease vacuum. look at the ifr table, it has kpa's across the top from 100 down to 20. the lower the kpa (vacuum) the more it increases pressure for engine load.
Old 07-18-2005, 07:59 PM
could this be the reason (cure) I am seeing the same injector pulse width wot with the 30lbers as I was with the 25lbers not scaled properly?
I also have a 17ms inj. pulse width running SD and 20 ms inj. PW running a tuned maf
any thoughts.
Old 07-18-2005, 08:11 PM
these are the scaled values I got from 0 to 80 kpa with
Injector Rated Fuel Pressure: 58
Your Fuel Rail Pressure: 58
Injector Rated Flow Rate 30
30.00052906 30.18750146 30.37332291 30.55801442 30.74159634 30.92408844 31.1055099 31.28587935 31.46521487 31.64353405 31.82085397 31.99719125 32.17256204 32.34698206 32.52046662 32.69303059 32.86468849
does this look correct
