2 Bar Map part # needed and any info with it.
Old 07-18-2005, 10:20 PM
618HAWK's Avatar
Default 2 Bar Map part # needed and any info with it.
Can anyone supply me with info for a 2 bar map. Would like to upgrade to a 2 bar map. Would like part #, and any related info.
Used search but no luck.
Old 07-18-2005, 10:41 PM
405HP_Z06's Avatar
GM PN# 12223861 3bar MAP
GM PN# 16040609 2bar MAP
GM PN# 16137039 1bar MAP
GM PN# 15305891 - pigtail harness
What specifically do you want to know about the 2 bar sensor?
Old 07-19-2005, 12:06 AM
618HAWK's Avatar
I take it these are oem part numbers. Looking for the best map sensor to fit a Holly-Weiland alum manifold for the LS1.
Old 07-19-2005, 07:41 AM
405HP_Z06's Avatar
These are OEM GM sensors, so I'm sure they will fit that manifold.
Old 07-19-2005, 09:09 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
www.hptuners.com sells a 2bar map setup for our cars. It's proven to work over 700rwhp and it's a complete solution.
Old 07-19-2005, 07:11 PM
618HAWK's Avatar
Great Thanks
I take it.... map over the maf setup, ie speed density is the way to go once you get above 1 bar??
Old 07-19-2005, 08:16 PM
405HP_Z06's Avatar
Great Thanks
They offer a 1 bar enhanced SD option also.
