how do you determine push rod size?
Old 07-19-2005, 03:33 AM
lowchevy2go's Avatar
Default how do you determine push rod size?
how do you know what push rod size to use is there like a rule of thumb on this or what ??
Old 07-19-2005, 02:42 PM
6 spd LT1's Avatar
depends upon your setup. do you have milled or unstock heads? do you have an aftermarket cam? if so does it have the same base circle as the stock cam?
anthony
