Manual Transmission - Slave Cylinder Install
View Full Version : Slave Cylinder Install
Xtnct00WS6
07-19-2005, 01:22 PM
I'm going to be installing an 01 slave in my 00 ws6 this weekend.
Any tips, install guides, wise words, threads that would help in the install process? I basically just need an install guide. TIA!
Steve Burger
07-19-2005, 03:43 PM
Try www.installuniversity.com and you can search google for t56 clutch replacement.
Ferocity02
07-19-2005, 03:47 PM
All you need to do is follow a clutch install guide. Then stop once the tranny is out. You might as well put in a new clutch while your at it. You will already be doing all of the hard work... But thats up to you, a new clutch isnt cheap.
Xtnct00WS6
07-19-2005, 04:21 PM
I didn't see anything on Installuniversity for a slave install. Do I have to pull the Tranny to install the Slave cylinder?! If I do, would I just have to pull it and the slave would be right there? I'm not even sure exactly where it is. I thought it'd be right next to the tranny? Would I have to bleed the system when doing a slave install? My clutch is okay for now, I'm definetly not trying to buy a new clutch now.
Steve Burger
07-19-2005, 05:33 PM
The slave is on the input shaft of the trans. You need to pull the trans out far enough to slide the slave over it. It is held to the input shaft with 2 10MM bolts. Use a clutch install guide to show you how. Yes you wil need to bleed after the install.
Xtnct00WS6
07-26-2005, 09:39 AM
Ok guys, I'm right in the middle of the install. I pulled the tranny, replaced the slave with the new 01-02 model and now I have a question.
Can I just pour DOT 4 fluid into the top of the slave (in that brass fitting that’s 11/16ths or 11mm) to get the air out and not have to worry about bleeding the entire hydraulic system? I’m not replacing the master at this time. I’ll be installing a new master in a few weeks along doing with the drill mod. So I’m hoping I can just bleed the system at that time.
I’m doing headers at the same time and just want to get my car working again. T.I.A!
GETSOMZ28
07-26-2005, 11:51 AM
If you bought the slave new, it should be pre-bled. No bleeding is necessary!
Xtnct00WS6
07-26-2005, 01:30 PM
Sweet. I can just put the tranny back in then! I wouldn't have expected GM to make it that easy to replace a slave.
Steve Burger
07-26-2005, 02:02 PM
You should bleed the entire system after the install.
Ferocity02
07-26-2005, 07:13 PM
The slave most likely is NOT pre-bled. Mine sure as hell wasn't. As Steve said, bleeding the system post slave install is mandatory.
GETSOMZ28
07-26-2005, 08:38 PM
All "288" slaves come pre-bled from the factory. It is always a good idea to bleed the line though. However, I would do the "reverse bleed" at the clutch reservoir than mess with the bleeder screw on the slave.
Xtnct00WS6
07-27-2005, 05:23 PM
What's the "reverse bleed"?
Since I don't have to have the tranny pulled in order to bleed the system, I'm going to put it all back together, see if I need to bleed the system and then I will bleed if I need to.
I really hope I don't have to though.
I have that stupid clutch sticking problem (thus why I'm doing this install) so I want to do one install at a time to see what the culprit was.
I'll let you guys know if I had to bleed after the slave. Have you guys done just a slave install and your clutch didn't work properly?
GETSOMZ28
07-27-2005, 07:10 PM
You need a mityvac or any handheld vacuum. Stick one of the little attachments into the small hole in the clutch reservoir. Pump the mityvac to ~20lbs of vacuum and watch the bubbles come out.
XCESPWR
07-30-2005, 02:50 PM
Xtnct00WS6, will you explain your problem in a little more detail?
I am having a problem with my clutch after the car is warm. It seems like the clutch isn't fully disengaging when i push the pedal down or go into neutral and thus causes the car to idle low and attempt to stall on me. I would lke to know your problem to maybe help me out in diagnosing my problem.
Xtnct00WS6
08-05-2005, 10:04 PM
When shifting at high rpm's my clutch would stick to the floor and I'd have to use my foot to pull it back up. I'll let everyone know if the slave was the culprit soon! I hope it was cause I have a new one in now.
Xtnct00WS6
08-08-2005, 07:47 PM
UPDATE:
I got the new slave in and it doesn't seem to stick anymore, but since I didn't bleed the system, the clutch feels a little off. It's hard to describe what's wrong, but it's def. not race ready.
The first time I put the pedal down it didn't come back up, but then after pumping it a few times, it gained pressure and seemed okay. It's not how it's supposed to be yet though. I'll have to bleed it and see how it goes. I'm almost postive that if I bleed the clutch it'll be back to normal.
Since I bought DOT 4 brake fluid, is it bad to mix the factory stuff and the new DOT 4?
