Are Flowtech headers the same as Hooker?
Hooker is owned by Holley which makes the Flowtechs. If you looks at the pictures they look like the same header. Am I wrong? Almost $135 less for the same painted header!
!LS1 11 Second Club
If recall from some photos, the Flowtech has a shorter, flanged collector. Hooker has a longer, slip fit collector.
Exhaust port flange in the Flowtech is flimsier from what I hear. One of the long tubes has a notch in it. I've heard Flowtech owner reviews range from "not bad for the price" to "oh my Lord, why did I get these?" (or something along those lines).
i thought the same thing as you and was considering buying a set, then i started hearing all these bad things about them cracking at the welds and the coating being no good. if your looking for a good deal on some headers, try out thunderracing.com they are running a special on pacesetter lt' and ypipe combos. i have pacesetters and alot of people on this board have them as well. good quality and the best for the price imo. if thats not the way you wanna go, then check out mac mids, they are good as well. all in all i say avoid the flowtechs.
My flowtech's are fine, little surface rust, no leaks, cracks or dents, and have been on the car for a little over a year. They are the same design as the hookers with a flanged collector instead of slip fit. The flowtech y-pipe is a POS!!!!!!!
